I have the following setup:
1 MS120-24P --> 1 MS220-8P
--> 1 MS220-8P
On the MS120-24P is an IPTV broadcast center (BCC)
On the MS220-8P are IPTV clients (smart TV and laptops with VLC)
All IPTV nodes are in a separate VLAN100
All IPTV nodes join VLAN 100 via access ports
On MS120-24P is an IGMP Querier configured
All switches have IGMP snooping enabled.
Now the issue:
The BCC sends about 300Mbps of multicast stream into vlan 100
If I look at my IPTV clients, I see 300Mbps of multicast going to these ports, even if these are not sending IGMP messages. In fact, there is no request for multicast streams whatsoever.
So why is the 300Mbps flooded?
The IGMP Querier is not really doing anything at the moment.
For the sake of clarification: the IGMP querier has an IP address in the vlan 100 subnet (172.16.20.0/24) but the BCC has an IP address in subnet 10.10.10.20.
I cannot change the BCC subnet right away (not under my management)
So what can be done to avoid the multivast flooding?
This is just a lab setup, but this will go eventually into production in large scale IPTV networks.
