I can't log in to the Meraki Dashboard.😪😪
How can you change the verification code from the authenticator app to SMS or email.Because my authenticator app doesn't work, I want the code as an SMS to my mobile number or my email.
Solved! Go to solution.
Is their another Meraki admin in your org that you could aks to help you?
Hi @Gislavedshus , I would reach out to Meraki support for assistance with that one
When you setup MFA via authenticator you get some OTP (One time Passwords) you can use as a backup.
If you don't have those, another Administrator should be able to reset it for you. Otherwise you'll need to call support.
