How to divide a growing network in two networks without loosing switch configs
redsector
Hello colleagues,
my Meraki Networks are growing. So I am thinking to divide a campus network in smaller building networks. I am worried to loose switch configs when moving them to another network.
Have you got an good advice how to do this?
thank you
2 Replies 2
MarcP
If you only want to transfer it to another network it should be only as following:
Example:
Wireless - Accesspoints --> tik checkbox of AP - "Edit" --> Move to another network -> confirm it
Just tried it, and it worked.
Nash
If I understand the documentation correctly, you won't be able to move a switch without losing the config:
https://documentation.meraki.com/zGeneral_Administration/Inventory_and_Devices/Moving_Devices_Betwee...
However, here's what you can do. Plan for an outage:
Use Postman to pull down as many settings as possible. Pay special attention to your switchports.
Save the resulting JSON in a folder.
Move the switch.
Upload those settings to your switch.
You could also get clever and write a script to pull your settings, move the switch, then update the moved switch with the settings.
