Hi @garak0140,
If you haven't already created your cloud dashboard, start there.
You can add your devices under Organization > Inventory or under Network-wide > Add devices once you have created a network for your remote offices.
You can then start the configuration of that network in your dashboard. When the devices are physically put in place and have a valid connection to the internet, they will automatically check-in to your cloud setup configuration and pull those configs down. Make sure your network is solid and running as designed before moving on to the site-to-site vpn setup.
See Meraki's documentation for more site-to-site vpn information. I think the documentation on their site can help you through most basic setup scenarios as long as you are familiar with networks in general.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
