How MS39048P Upgrade default power supply to 715W and 1100W ?
Noraseth
 Please advise . How MS39048P Upgrade default power supply to 715W and 1100W
6 Replies 6
DarrenOC
Hi @Noraseth , you’ll need to order the below part code then swap them over
MA-PWR-1100WAC
Thank you, but if I want order MA-PWR-1100WAC to default primary  it can do?
DarrenOC
Hi @Noraseth , it would be a simple case of ordering the part. Power down the switch. Remove the 750W power supply and replace with the new 1100 PSU
Sorry. i mean when qoute first step on CCW default  power supply is 715W . it can not change or edit  to 1100W  ^^
Please how to change default to 1100W before order to Cisco.
DarrenOC
hi @Noraseth , ah, see what you mean now.  Just tried within CCW myself and it looks like you can't replace the default PSU with the upgrade SKU.  Reach out to your Meraki AM and see if there's anything they can assist with.
You can do it with a 3850 or 9000 series switch so why not with the ms390.  let us know how you get on.
GreenMan
I think you'd just order MS390-48U instead.
