High Rate of STP topology changes
AhmedJawad
Is there is anyway i can find the bridge ID of the switch that is generating the STP changes can I see something in the logs maybe?
DarrenOC
Hi @AhmedJawad are your endpoint ports configured in port fast mode?
how do you configure portfast on Merkai port? I dont see that option.
It happens when you configure a port as an access port.
Every time a trunk port goes up and down, an STP change will occur.  It doesn't have to be triggered by another switch.
