- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Forescout and Meraki
We currently have Cisco ISE, but are looking at Forescout for 802.1x Authentication. Does anybody have any experience with this?
Thanks,
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I haven't looked into Forescout but are you a Windows AD environment? Can't you just use NPS on a Windows Server for 802.1x? Seems to work fine in our environment.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Adam,
We are doing so much more with Cisco ISE now. For non standard devices, we are using MAC authentication and profiling. Management wants to move to Forescout, so I am wondering if anybody has used Meraki and Forescout.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We have done this successfully with Meraki and ForeScout. ForeScout supports Meraki Wireless APs (MR) and Switches (MS) for authentication, authorization and guest management. This is provided via RADIUS and CoA with ForeScout CounterACT being the RADIUS/802.1x server.
For more information on the CoA and take a look at the following documentation on Meraki’s portal (which mentions ForeScout): https://documentation.meraki.com/MR/Encryption_and_Authentication/Change_of_Authorization_with_RADIU...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks. Are you using CoA with ForeScout? Do you have the span port going to ForeScout? Are you using an agent?
Sorry for the tons of questions. If you don't want to put this all out in the forums, you can send me a PM.
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey Chris,
We successfully tested RADIUS CoA on Meraki Wired & Wireless. We do provide SPAN to ForeScout to allow enhanced visibility, e.g. DNS, DHCP traffic. While we tested both in the end we did not use the ForeScout agent, since we can do most of the endpoint assessment without it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello CiscoKid14074, can you point me to some good documentation on how to integrate ISE 2.3 and Meraki Wired? I am looking for posture, dACL, redirect (for client provisioning), CoA for dynamic VLAN assignment. I'd appreciate it.
