FW HA Failover Seems to Have ISP Preference
MarcW
I chose switching since this is where we are seeing it.  We have 2 ISP's.  They both hit the 8 port switch which then hits each of the FW's (primary and spare).
If we fail ISP #1, the network stays up, but the switch reports as down.  How do I make the switch follow the other ISP as the primary?
7 Replies 7
Theoretically this is supposed to be automatic. Do you have any traffic routing rules (Flow Preferences)?
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
MarcW
No routing settings.
You could give the switch a private address from the firewall lan side
Check out the slide deck shared in this post
https://community.meraki.com/t5/Security-SD-WAN/How-to-turn-MS120-into-WAN-breakout-for-2-ISPs-and-2...
MarcW
I will look into this.  I may have a completely different ISP setup when we move to the actual location and this will change how I can offer IP's to the switch and MX's.
Ryan_Miles
Is your 8 port switch doing WAN breakout like shown in my diagram?
https://docs.google.com/presentation/d/1xsb8imtUFjN13so86kIZ04IR9f6WEKdbpUrYVON64Zg/edit#slide=id.g1...
And if yes, is the mgmt VLAN of the switch coming from the LAN side of the MXs?
It will failover - but it will take MUCH longer.  Around 5 minutes.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Connection_Monitoring_for_WAN_Failo...
MarcW
My install is next week, so unless there's a time limit, I am going to keep this open.
