Dynamic ARP Inspection on MS 120 Does not working
Kave
kav noroozi
Correct.   It is only available on the layer three switches.
5 Replies 5
timeshimanshu
if you are running MS120 then your MX would be probably working as L3 Gateway. Check on your MX ARP table.
This feature is unsupported by MS120
Kave
Thank you,
But I could not find any Dynamic ARP Inspection on MX series, It is just L3 switches capability I think. 🙂
kav noroozi
SoCalRacer
Not supported on the MS120 model.
Supported Models are listed in this document and more info regarding the feature.
https://documentation.meraki.com/MS/Other_Topics/Dynamic_ARP_Inspection
Kave
Re: Dynamic ARP Inspection on MS 120 Does not working
I could not find any Dynamic ARP Inspection on MX series, It is just L3 switches capability I think. Smiley Happy
kav noroozi
