Does MS support NAT ?
kuni
In case of L3 Model above MS250, Do they support nat function ?
If I don't use MX, Can I use MS instead of MX ?
I mean that MS connect to Internet circuit directly and set NAT to use internet for internal clients.
BrechtSchamp
No, the switches can't perform NAT. You'll need an MX or another router for that.
BrechtSchamp
kYutobi
MX supports NAT not MS.
Enthusiast
BlakeRichardson
Ignoring your NAT questions completely even if you had a connection that didn't require credentials using a switch as a router would be a bad idea, switches do not have any type of intrusion prevention.
