Dashboard configuration issues - BETA IOS XE 17.15.2
efdiaz
Wondering if anyone else is seeing this issue or can test this issue. I applied a configuration change on a Cisco 9300s running BETA IOS XE 17.15.2. Been waiting on the link to come up on the other side and it has been over 30 minutes since the changes have been applied.
Looking through CLI, the port is still showing as an access port and is still disabled. Just tried it on a non-beta 9300 switch running Meraki. Configuration change took about 2 minutes to apply the change.
Seems to be a Dashboard to BETA OS switch issue.
1 Reply 1
Mloraditch
I'm not aware of this specific issue, but you may want to upgrade to the 17.15.3 RC when you can. Nothing fixed seems directly related, but Meraki doesn't always post all the bugs that have been fixed.
EDIT: There was a previous issue that was fixed via a backend change, but it reads as a global change: https://community.meraki.com/t5/Switching/IOS-XE-17-15-2-not-saving-config-changes/td-p/265607/jump-...
