DHCP Snooping
errolngrant
DHCP Snooping
Does this comes automatically enabled or is this something that needs to be turned on?  Have not found any steps but see that it is a feature of the product.
GIdenJoe
It is enabled by default but it does not take a blocking action until you explicitly block a server MAC address or you put the default policy to block.
Ray_L
Just browsing
Hello!
Though not mentioned as DHCP Snooping, the MS devices do display DHCP communication observed across L2.
More info can be found on these two KB:
https://documentation.meraki.com/MS/Monitoring_and_Reporting/MS_DHCP_Servers#Detected_DHCP_Servers
https://documentation.meraki.com/MX/DHCP/Tracking_Down_Rogue_DHCP_Servers#Cisco_Meraki_Switches_(MS)
DarrenOC
hi @errolngrant - not much you can do here with regards DHCP snooping except block rogue DHCP servers off the network:
MS DHCP Servers - Cisco Meraki
GIdenJoe
