Policy based routing on an MS Switch stack
MXITCA
Hi
We have an MS425 core aggregation stack with several VLANs on it configured and several access stacks lower in the topology using these VLANs, now we need to be able to use policy based routing on that core stack and route default traffic from a VLANx to the internet via a different Gateway.. I see this is not supported on these switches, while they are Layer 3 though..
Any clue if Cisco is ever planning to have this feature implemented? and anyone knows what would be a suitable workaround? making sure that inter VLAN traffic keeps flowing via that core stack?
PS: Uplink we don;t have any MXes to use traffic flow
2 Replies 2
There is no policy routing available with the MS family yet. You can "make a wish" for the Meraki team.
You can only do normal forwarding - based on the destination address.
You'll probably need to move the gateway for that VLAN from the MS to the "Internet Gateway", and have it route all internal traffic back via the MS.
