DEFAULT ROUTE FOR CISCO MERAKI MS350
Censystems-Prev
I have a management network where a Cisco MX device acts as the default gateway for my networks and is connected via a trunk port to a Cisco MS switch. When I manage the MS using DHCP from the MX, everything works fine. However, when I switch to a static IP configuration on the MS, I lose administrative connectivity.
I have already made adjustments to the VLANs and configured static routes pointing to the MX, but the issue persists. Does anyone know what could be causing this problem?
I’d appreciate your help!
7 Replies 7
Are you assinging a ip in a switch L3 vlan?
Its recommended to have a switch management ip in the vlan on the mx. So that the switch doesnt need to route its own management traffic.
Does the mx have routes to the switch vlans?
Censystems-Prev
Hello thank you for your answers
My situation is there:
My MX have default gateway for my vlans and DHCP only for Specific segments, i have a management vlan 90 and i have the following address
192.168.90.1/28 Default Gateway for MX
192.168.90.5/28 for MS but this address its with DHCP from MX
i have a interface trunk between MX and MS with native vlan 90, when i remove the DHCP in MX and put the address 192.168.90.2/28 for my MS a lost the administration from dashboard. I put a interface L3 but not resolve the issue.
If i use a catalyst swicth the configuration its resolve with command ip default-gateway but in Meraki i dont know what happen.
So u configure this, and then you lose connectivity?  .2 is not in use already?
Censystems-Prev
Its correct when i put this configuration and remove DHCP from MX i Lost the MS
Censystems-Prev
MS
MX
TRUNK
DHCP From MX
this is currently
DarrenOC
Agree with @ww - the switch can’t have its Management L3 VLAN interface on itself.  So in your case the Management VLAN interface will reside on the MX
