Connecting a MS220-8P switch to a MS120-8FP switch to establish network connectivity will this work?
phelimmc
Can anyone advise please the MS120-8FP switch we use is networked and live. Is it possible that we can connect a MS220-8P switch to it by network cable to establish network connectivity on it also. We have set both ports on both switches to the same native VLAN, allowed VLANs set to all and disabled POE on both ports that we will connect the network cable on both switches. We plan to connect the network switches then by network cable so the MS220-8P is networked? is this possible between these two switch models or will it only work on a like for like model?
Ryan_Miles
Meraki Employee All-Star
Yes, you can connect any two switches together with standard front side port. No problems here.
1 Reply 1
Ryan_Miles
