Configure LACP on switch stack using switch profile
JohanAnderstrom
Hi!
We are looking to use Switch profiles within a template and bind these profile to a switch stack, which is fine and works.
We also want to create a LACP aggregation between unit 1 and unit 2, this does not seem to be possible when binding a stack to a switch profile?
The only possible way to aggregate two ports is on the same switch, I am not able to aggregate one port on each unit.
Thank you in advance!
Best Regards
Johan
1 REPLY 1
I don't think that would be possible.
You should be able to do it after you have applied the switch templates by overiding the port configuration.
