Clone a MS-120 to MS-150 Switch
CharlieCrackle
Am I missing something...   Upgrading a switch from MS-120 to MS 150 (same number of ports)    you can not clone between models.   ?????????    All I want to do is clone the port descriptions VLANs etc from 1 switch to another....
Is they a way to do this...
Even if I do manually there is not 1 page to do this easily.  It is port by port config per page
Not looking forward to this upgrade !!!
Mloraditch
You are correct, cloning only supports same model cloning.
You would need to use the API to do this otherwise in a non manual way:
https://developer.cisco.com/meraki/api-v1/get-device-switch-ports/
https://developer.cisco.com/meraki/api-v1/update-device-switch-port/
There are a couple of other calls in this category on the documentation link above that could also help.
Blue_Bird
Mloraditch
CharlieCrackle
Cisco please add to the wish list to be able to copy between models   even a copy from a 24 to 48 should be supported.. (just the bottom 24 ports)
@CharlieCrackle I'd argue a 24-48 should copy 1->25 etc. as the 24 ports are on the right hand side where 25-48 are on the 48 port model, but anything would be nice!
