C9300L-24P-4X-M - what copper SFPS can i use
robertjubb
On the datasheet it doesn't even mentions a copper SFP-- can a GLC-TE be used -- ?
9 Replies 9
Have  you checked this list?
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
And this one.
Optics Compatibility Matrix
robertjubb
thanks top one -- says the meraki copper one Not supported MA-SFP-1GB-TX  but the cisco SFP check says the cisco equivalent switch can take a GLC-TE= so would think it should-- but need someone one tried it
robertjubb
think the top one is also says  Click this LINK for a filtered list of all optics for C9300/C9300L/C9300X platforms - so i think they will work -- but any one tried on a new 9300 M model
It's not supported.
https://documentation.meraki.com/MS/MS_Overview_and_Specifications/Catalyst_9300L-M_Datasheet
robertjubb
the GLC-TE_ is just checked
robertjubb
yes no mention -- but this-- send you to the 9300 section which says GLC-TE= is compatible-M models are the same hardware just running natively in Meraki mode.
Brash
Will it work? - Almost certainly yes.
Is it supported? - Based on the note you mentioned above; the GLC-TE is compatible. However if you are troubleshooting issues that indicate the SFP may be a problem, I could see Meraki support may request you to swap in a MA-SFP-1GB-TX to rule it out.
