Best Practices for configuring Vlans across different floor switches
What's the best practice of configuring vlans across different floor access switches. Do we need to create separate vlan for wireless (corporate users) on floor basis or a single wider subnet is enough to cover all the floor ?
Accepted Solutions
Re: Best Practices for configuring Vlans across different floor switches
I'm with @AjitKumar - a single VLAN for WiFi users to allow easy roaming.
5 REPLIES 5
Hi @Visakh_v_r
I would prefer "Single" VLAN across floors.
Regards
Ajit
ajitsnw@gmail.com
I would also suggest setting up a management VLAN, also a separate guest VLAN and SSID, prefer not to use the native LAN and lastly tag all the VLANs.
Thanks for your Hint. Nice share.
