After factory reset of Meraki MS120-24 equipment
meraki222
Just browsing
I have a question about not being able to access the 1.1.1.100 web page after factory resetting the device.
rwiesmann
I guess you followed the information out of this document...if not check it out
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
You also can use the dedicated managmentport without the need to set the ip statically.
what type of switch do you have?
Did you plug into the management port?
meraki222
Just browsing
I connected it to the UTP port in front of the device, not the management port.
