1Gig uplink on MS130-24X
ammahend
Hi community, can I connect MS130-24X-HW or MS130-48X-HW uplink with 1Gig although its SFP+ has anyone tried and confirm if it works ?
5 Replies 5
No, both ends must have the same type of connection and the same speed.
ammahend
I am asking if the SFP+ uplink is backwards compatible with 1Gig also or I can only connect 10G SFPs ?
I will obviously connect both sides with 1Gig. I am not going to connect 10G on one side and 1Gig on other side 🙂
If you put a sfp in the sfp+ slot you can
Take a look for supported modules
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
DarrenOC
It will work.  If you have a 1Gbps SFP at both ends then you’re fine.  As @alemabrahao alludes to you can’t mix the SFP types at either end.
GIdenJoe
10 Gig SFP+ ports are backwards compatible with 1 Gig SFP's.  25 Gig SFP28 ports are backwards compatible with 10 Gig SFP+ and 1 Gig SFP modules.
100 Gig QSFP28 ports are backwards compatible with 40 Gig QSFP+ ports. 🙂
