17.1.3 Upgrade
Slobs2
17.1.3 Upgrade
Since going from 16.7 to 17.1.3 I've been experiencing all sorts of odd network issues. The biggest symptoms are seeing my SNMP monitor showing different servers/endpoints going up and down but more concerning is VoIP issues. Having calls either that the caller can't hear the other person or vice versa. I do all my layer 3 on MS425s and edge switches are MS350s. Support is helping by downgrading the firmware on the two 425s. Anyone else seeing issues like this with 17.1.3?
1 Reply 1
thomasthomsen
Sorry, I have not seen that issue on 17.x.
I have only experienced "fun" things with Smart Port Automation and trunk ports.
Where the port, after being set to trunk by the Port Automation, seemingly stops forwarding packets on non-native vlans. The switch however says that there are clients on that port, in tagged vlans on the port, when looking at the mac address table.
