100 Mb Fiber SFP
100 Mb Fiber SFP
Has anybody had a requirement for a 100Mb Fiber connection directly to a Meraki switch? Due to the environment where the switch will be installed we cannot also install a fiber converter. Meraki say they don't support 100Mb SFPs but has anyone had this requirement and perhaps got a 3rd party 100Mb SFP to work?
2 REPLIES 2
Re: 100 Mb Fiber SFP
Part of the problem is some 100Mb/s SFP's are full duplex and others are half duplex.  They are "baked" in that way.  Because of this they often don't communicate the link state correctly when used in a traditional Gigabit SFP slot.
If you have Meraki kit at both ends check out this compatibility guide and see if their is something else that can use your grade of fibre.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
Thanks Philip,
Its a piece of equipment used in an oil field that will be connected to the switch. It sounds like we might be out of luck.
