MS250 wont connect to Meraki Cloud
cocacond
Received MS250 and trying to get it to show up in my portal.  Have switch on an internet connection.  Checked management interface and the switch sees the cloud but won't connect.  Any ideas?
8 Replies 8
you added the serial number to the dashboard?
does it give any error/info on the local status page?
try with static ip settings.
try factory reset it.
cocacond
No error info and everything is added to the dashboard.  WIll try static and Factory reset if that does not work.  Thanks
jdsilva
What type of SFP are you using in the WAN port?
cocacond
Just using a patch cable plugged into a normal switch port
LeonG
Hi cocacond, Iam having the exact issue with the ms250. How did you get this resolved?
Thank you
cocacond
In our case, it was with our policy of not using VLAN 1 in our environment. We had to make changes to get the connection to the cloud but after that all was good. And from AjitKumar these are some good steps
1. Try factory resetting the device.
2. The device is successfully added in the dashboard.
3. The upstream firewall is not blocking reach-ability to cloud.
4. The Default VLAN1 is used for management traffic.
5. The up link port is a Trunk Port.
6. Port Speed (Uplink Port) at the Local Status Page. They should negotiate.
Hope this helps, if not let me know.
AjitKumar
Most of the time the Local Status Page shall display the reason. Why a device is not able to reach the cloud?
Could you please re-verify the following.
Hope this helps you.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
I assume that the port it is plugged into can access the Internet.  I assume the switch it is plugging into doesn't have anything turned on like BPDU guard, port security, or other protective measures.
A lot of the time with new switches you need to plug them in and leave them for 30 minutes while they do initial firmware updates.
What colour(s) is the status LED?
What does the local status page say?
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
