Search instead for
API - Returns a different timezone
Hi there ,
I'm currently using the API call :
GET /networks/{networkId}/devices/{serial}/lossAndLatencyHistory
 and the return is something like :
"startTs": "2019-04-07T02:54:00Z",
"endTs": "2019-04-07T02:55:00Z",
"lossPercent": 0,
"latencyMs": 13.5
although my timezone is curently configured as UTC -4 ( Montreal , Canada ). I know I could easly modify the output in python. But any idea why the output is UTC 0 instead of UTC -4. Can anyone test it and confirm that ''issue''.
Thanks a lot
1 REPLY 1
Re: API - Returns a different timezone
It's probably by design to avoid confusion.
The Z in the time tells you the returned time is in Zulu time aka UTC.
