Hi @Ryan_Miles
I've now tested this and it appears to have a bug (I have raised case).....
I have a SAML role that grants Org Read Only "Org-RO", and a Camera and sensor role that denies access to all cameras and all sensors for all networks called No_Video.
Azure is passing across both roles "Org-RO;No_Video" ok.
If I login with this account and go direct to a VideoWall - it works great, every single tile in the wall says "Video Access Denied".
However, If I go to the Cameras-Cameras page, it lists the cameras ok. I select any one at random, it displays the cashed B/W image and flashes up "Video Access Denied" - but it then proceeds to display a live feed !!!!
Moving between cameras using the < and > does not displaying anything in the Video tab (correct). But navigating back to the cameras page and selecting another camera does the same (displays BW image, Video Access Denied" but then proceeds to display live feed!!)
Exact same issue if I replace Org Read Only with a specific Network Read Only.
