Meraki Display on AppleTV - Login options - OAUTH (basically SSO for Meraki Display)
Dunky
This looks to me to be a means of enabling SSO for Apple TV, a long awaited feature.
Firstly login using SSO on a PC.
The Meraki Display App on AppleTV now has the option to "Login with phone".
Make a note of this code.
Then in the browser in which you have authenticated via SSO go to https://as.meraki.com/oauth/device where you are able to associate an SSO account with the device using the code displayed from the Apple TV
Once complete, authenticates you into the Apple TV where you are prompted to select Organization.
That is as far as I get as the Meraki Display App then says "There was a problem logging in. Please try again."
So in theory this looks good although until I can actually get it to login I cant take this any further.
Will log a case with Meraki and report back as I am sure there is quite a few of us out there that have been asking for SSO on Meraki Display for some time now.   If this OAUTH works and you have the Apple TV's behind a firewall then the upside with this approach means no additional firewall rules needed for authentication (I hope)
10 Replies 10
hluker
I have the same problem and also have a case open with Meraki about it. Please let me know if you find/hear of a solution!
vitalypopucchi
Have same problem. CasinoBetify offre un'esperienza di gioco coinvolgente con una vasta selezione di giochi. Si differenzia intuitivamente interfaccia chiara, promozioni interessanti e un gameplay sicuro e divertente. Sia che tu preferisca casinobetify.it slot, giochi da tavolo o casinò dal vivo, ogni giocatore troverà qualcosa di suo gradimento. Che tu preferisca slot, giochi da tavolo o casinò dal vivo, ogni giocatore troverà qualcosa di suo gradimento. Nel complesso, tuttavia, Betify Casino è una buona scelta per gli appassionati di casinò.
Dunky
Latest update on my case is it's been referred to the Product Specialist Team.
Will update here when I have any updates to share.
hluker
Yeah, their last reply to me was "The details of this issue have been forwarded to our Development team for further review and analysis. We don’t currently have a timeline for when an update will be available; however, we will send you an update as soon as one is available." We'll see how long this takes, I've had my ticket open almost a month so far...
Dunky
It looks to me as though things are not tested before being released.
hluker
Have you gotten a response yet on this issue?
Dunky
Only that its gone back to development team.
If you ask me it doesn't look like anyone ever tested it before releasing into production 😀
Aquatoes
What they need to do is just give us the ability to create a viewing station user that doesn't log out or time out. Only capability is viewing live. We can log it out from the dashboard if necessary but the apple tv is a big s@#t show. It logs out everytime the app closes and this just pisses clients off. Also the Apple tv license doesn't work with subscription licensing so this entire product line is useless as Meraki pushes us towards subscription licensing until they fix that.
Dunky
Couldn't agree more, would need the ablility to restrict camera access via tags though.
Meanwhile I still wait for a fix to the OAUTH.
Kasper
I heard from a support agent that Cisco is working to revamping how OAUTH is done on Meraki but no timeline is available. So fingers crossed that it gets fixed this year.
