Meraki Camera is in DORMANT state - how to fix
Nasser-ps
Hey Everyone,
My Meraki camera is currently in the DORMANT condition.
I am aware that a device in a DORMANT state is one that is not connected or has been offline for more than a week.
I then conducted some troubleshooting and accessed to Meraki dashboard> cameras>The targeted camera>Network.
I also observed the following:
  • The camera is not connected to any switch, as indicated by Ethernet 1 on the left sidebar.
  • I restart the camera, but nothing happens!
  • I "pinged" the camera, but nothing happened.
Is that evidence that the camera is actually disconnected, or might there be a different problem?
Have you opened a support case?
It looks like a hardware issue.
ConnorL
A dormant device as you mentioned means the device hasn't contacted the cloud for over a week, the ping and reboot live tools, therefore, won't work if we have no contact with it.
I would advise physically checking if the MV is plugged into the network and if it is powered on, if so, follow our troubleshooting KB: https://documentation.meraki.com/MV/Troubleshooting/Troubleshooting_and_Replacing_a_Faulty_MV
BlakeRichardson
If you plug a device into the port that the camera is connected to can you access the internet from it?
I would go back to basics ad double check the cabling and is the device powering up, followed by the configuration of the switch port + routing.
