MV snapshot
Salma1
MV snapshot
hello dears,
I just need a help. how can I get a snapshot from the MV in a specific time in day and compare the snapshots with the exciting pic I will determine if it identical the system should sent an alert to me? is it applicable?
thanks in advance.
Take a look at this.
https://developer.cisco.com/meraki/mv-sense/overview/#example-use-cases
Salma1
Hi Alessandro,
I have applied the API on MV 22 and get a scheduled snapshot it's ok and fine. but my question it's according how to compare between two pictures.
thanks.
To do this you need an analytics tool and with Merki you unfortunately won't get it today.
Unless you have an extremely controlled environment, you are not going to get pictures exactly matching.  Simple things such as a change in lighting will make them different.
It sounds like you are looking to identify some kind of change.  This is probably a good use case for AI.  This is something that will take quite a time investment.
If you don't mind spending some money, there is bound to be an existing company that makes an AI product that does this:
https://apps.meraki.io/en-US/listing?q=AI
