Hello;
I have a MV-72 that I am trying to install with an 802.3AT POE injector. For some reason, the MV boots into a blue flashing light, which according to the installation manual says it is looking for a wireless connection. I tried it into different ports on the switch it is connected to (also other cameras are connected), but no luck.
Any Ideas? Thanks in advance
If you plug a notebook into the same cable does it work?
yes
Have you got a PoE switch or a different PoE injector you can test with?
I assume the overall cable run is less than 100m including patch leads?
I'm thinking two potential issues:
* problem with PoE injector
* problem with cabling, such as attenuation is too high
I am going to test the camera on another network with a known good switch and a good cable, I will update tomorrow. Thanks for the input.
It was actually the cable that came from Meraki with the camera that was bad. I have never seen that before. Thanks for everyone’s help!!
