MA-PWR-ETH
Takaki
MA-PWR-ETH
I have a question about MV2.
According to document, it looks customer has to buy MA-PWR-ETH but I can’t see this PID on CCW.
Could you give us some advice, please?
Inderdeep
@Takaki : May be check with the different price list if you can. I think this still needs to be added in CCW. I tried it with the Global Price list for Canadian and APAC and not found !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
6 Replies 6
Inderdeep
DarrenOC
Not available on Global List EMEA either
KarstenI
As a customer, I typically would not buy this adapter. Why waste an Ethernet-port when a plain USB-C adapter does the job. The only reason I can think of is if there is only ethernet available and the next power plug is far away.
Inderdeep
@KarstenI : well i think @Takaki is thinking of the requirement if customer ask of the specific SKU. As this is the option as well, customer may go with that as well if needed !
chadsmith
I can definitely see larger customer who would want to power this because of proximity and cost to run power, plus the additional monitoring of power to the device.
DarrenOC
From the datasheet it looks like you can also power by MA-PWR-USB-XX
https://meraki.cisco.com/product-collateral/mv2-cloud-managed-smart-cameras-datasheet/?file
