How can I track an object with APIs?
Takuma
Hi All.
I want to track an object with APIs.
For example, "Raw Detections"(Sense API) have "frame" and  "oid" parameter.
but , This value is changing every moment even if the same object.
How can I track one single object?
Please tell me the way if you know.
Regards.
Isn't there an object ID field or something like that?
Takuma
Hi Philip
Thanks for your reply.
I know "oid" in raw detections , but is this value fixed even if the same object?
It's not the same value as long as I tried with the api.
 Regards
Takuma
I explained that badly.
The value often changes even if the same object.
