Camera access limiting
Ryan11
Can you think of a way to create a live view only account that is only allowed access from inside our network? We have a third party security company and don't want the user to be able to access cameras from outside.
I know you can restrict the IP that can access to dashboard under Organization > Settings > Security > Login IP ranges, but it's for the entire organization.
Ryan_Miles
Meraki Employee All-Star
Video streaming from outside the network would use cloud proxy which runs on TCP port 30001. So, you could block that and it would prevent viewing unless the viewer was on the internal network (or VPN with access to the cameras).
You would have to use SAML authentication and apply a restriction on what machines are allowed to access the Meraki Dashboard.
@alemabrahao's suggestion is good, but it will limit all Dashboard and API access.
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Organization_Menu...
