Camera Role Based Access
MuhammadHasan
Hi Community,
We have some Meraki cameras in the dashboard and SSO is already enabled. All of the users are using SSO to log into the dashboard. I want to restrict some users from accessing cameras while using SSO. any suggestion
5 Replies 5
Have you checked the documentation?
https://documentation.meraki.com/MV/Advanced_Configuration/Restricting_Access_to_Cameras
Ryan_Miles
@MuhammadHasan in addition to the link @alemabrahao provided I also have a slide deck that walks through some examples of Camera and Sensor roles using SAML with my IdP. Sharing the link below in case it's helpful to you.
Link to deck
Ryan
MuhammadHasan
@Ryan_Miles Thanks mate. Its really helpful but can you please let me know how to do the config on SMAL side also how and where to implement in meraki dashboard
Firstly, https://www.youtube.com/watch?v=-d37z6qCGLQ
And when you get to the Consumer URL part, you can use :
 The vision one instead of the normal one
