Alert email if any camera Retention is less than 90 days
satyamothukuri
I am looking for alerts or report to run on cameras that has Retention less then 90 days.
Will there be any help from support ?
Satya
2 Replies 2
Currently, Meraki does not offer a built-in alert or report specifically for cameras with retention below a threshold like 90 days.
But you can use the Dashboard API to pull retention settings and motion data per camera or create custom reports using the API to flag cameras with estimated retention below your desired threshold.
Take a look at the benefits of Smart Retention.
Smart Retention - Cisco Meraki Documentation
BlakeRichardson
The only way the get this information from the dashboard without using the API is to look at each camera, even the camera list doesn't have an option to see retention figures.
