- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MTI5 Showing Port disconnect
Hello Guys,
I installed MT15 between 6ft to 8ft from the ground based on the installation guide in the datasheet. The MT15 is connected to MS120. I observed the port the MT15 is connected to the MS120 is showing (Port disconnected), I tested the ethernet cable and it's all in good condition and also tried to connect MR36 to it and the device came online and shows the cable is ok. Please what likely can be the issue? Thanks
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is accurate. There is no IP Stack on the MT sensors so the only way the communicate to the dashboard is through the gateway they connect to (MV or MR). The ethernet option is STRICTLY and only PoE today.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The MT15 uses Ethernet for PoE, it doesn't establish a data link. On my home switch for example I see it drawing power but the link doesn't come up. It uses BLE to connect to MR/MV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is the same I observed in the MT15 I installed. Is this normal?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To the best of my knowledge, the PoE option for the MT15 is for power only. It is not used for data.
I think this is expected behaviour.
It communicates using Bluetooth to a modern MR or MV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you, guys, for the detailed shared information.
