MT14 short memory
MT14 short memory
I was sure that the MT10 sensors retained about 7 days of data should they lose contact with the network, or am I mistaken there?  In comparison I found that an MT14 that has lost connection only retained the last 12 hours of data when reconnected.
Has anyone else had experience of this?
OllieGerrard
Because of the frequency rate and high amount of measurements on the MT14, the on-board storage is unable to store 5 days of measurements before it gets re-written - I'll make sure this gets mentioned in the docs too and it's something we're investigating for improvements in the future.
Ryan_Miles
Meraki Employee All-Star
Should be approximately 5 days per the doc. I’d open a case to see why they can find if you’re not seeing that and it was powered for the last 5 days at least.
OllieGerrard
Thanks both @OllieGerrard and @Ryan_Miles, very happy to have a quick pair of definitive responses 👍
