MT10 Cabinet mount
Stealth_Network
MT10 Cabinet mount
Just testing the MT10 sensor and the server cabinet has a non-flush mount door. The door is about 1/2" farther out than the enclosure. I see the documentation says "flush mount" and I understand the distance from the sensor to the magnet, but is there a height minimum between the sensor to the magnet?
Looking to add some thicker double sided tape to bring the magnet further out, I just need to know the tollerence.
1 REPLY 1
It sounds like an easy experiment you could do on your desk moving them slowly closer together until it registers as closed ...
Then deduct a bit more for when the battery starts to drain.
