Feb 2 2021
10:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Feb 2 2021
10:39 AM
API?
I've searched, but am I correct that there is no API for the MT sensors currently?
Solved! Go to solution.
Feb 2 2021
10:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Feb 2 2021
10:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Feb 2 2021
10:56 AM
I can't find an API for the sensors.
Feb 2 2021
10:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Feb 2 2021
10:58 AM
Thanks, I needed a sanity check since it's in the sales material and I had no luck.
Feb 3 2021
9:47 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Feb 3 2021
9:47 AM
API for the MTs is currently in Beta. You can contact Meraki Support to enable it on your Organization.
Once it's enabled, you should be able to see the endpoints under Help > API Docs.
If you found this post helpful, please give it kudos. If it solved your problem click "Accept as solution" so that others can benefit.
