Correct. The vMX100 is only used as an AutoVPN endpoint.
I wonder about its cohabitation with an MX that has Advanced Security in the same Organization. You cannot mix and match Advanced and Enterprise licensing in the same organization. So, if you have a Z3 user, you must create a new Organization for just that user.
They need to fix that. Such a pain.
