vMX100 License
BS
vMX100 License
Hi all,
If I buy a vMX license does it come with IPS/AM features?
Regards
BS
7 Replies 7
NolanHerring
Fairly certain that those functions are not included with the vMX, its strictly an Auto-VPN concentrator
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Which means we need to have next generation features on a different box?
NolanHerring
"Virtual MX is a virtual instance of a Meraki security appliance, dedicated specifically to providing the simple configuration benefits of site-to-site Auto VPN for customers running or migrating IT services to an Amazon Web Services or Microsoft Azure Virtual Private Cloud (VPC)."
So you basically would want to apply any of your IPS/AMP/L3/L7 policies/rules at the SPOKE (say an MX65 at a remote site) where as the vMX would be your HUB to simply terminate the vpn tunnels.
TwitterLinkedIn
NolanHerring
Pretty sure that you'll need to have the Advanced Security licenses on the spoke MX appliances in order to get those features.
TwitterLinkedIn
The vMX can only be a VPN concentrator and nothing else.
Correct.   The vMX100 is only used as an AutoVPN endpoint.
I wonder about its cohabitation with an MX that has Advanced Security in the same Organization.   You cannot mix and match Advanced and Enterprise licensing in the same organization.   So, if you have a Z3 user, you must create a new Organization for just that user.
They need to fix that.   Such a pain.
The VMX is an exception.  You can have a VMX and other devices with Advanced Security in the same organisation.
