Hi
I notice the deployment of the vMX into Azure associates an Azure Public IP address with the vMX/Managed Application.
Presumably it is this public IP address that is used for inbound and outbound vMX connectivity. This vMX is therefore on the perimiter of the Azure network directly exposed via a public ip address.
I have a couple of questions:
Of course, if we were using the native Azure VPN Gateway (and not Cisco vMX say) then that would sit right at the perimeter. So it may be that it's the same principle with vMX, in which case that's fine. I really just need a view on this though to sanity check this.
Many thanks for any help in advance.
Paul
Solved! Go to solution.
The vMX is just a virtual MX - which is itself a firewall
Yes, you can have the vMX sit behind another firewall if you like.
Within the Managed Application resource group there is a public ip address that is assigned to the vMX vm. I presume that has to remain there as the resource group is locked?
Thanks.
Check out this video on deploying a VMX behind a virtual router in Azure. You would just substitute in a virtual firewall instead.
Does the vMX in azure have firewall functionality enabled, as it can only operate in Single Armed Concentrator mode (L2)?
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Microsoft_Azure
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Addressing_and_VLANs
In the Physical form of MX when in concentrator mode you need another MX sitting infront in Routed mode to provide Firewall Services.
When it has a single interface it can't act as a traditional firewall allowing traffic to flow between two ports BUT it is still a firewall in the sense that it is protected from threats, and you can directly connect it to the Internet (although that really isn't the case with Azure since Azure is NATing from the public IP it assigns to the private IP that it gives the VMX).
