vMX configuration
AMU_2022
Just browsing
vMX configuration
Hi community,
Has anyone of you already configured a vMX in routed mode in Azure?
I am not getting accurate statements from Meraki support.
Here's the deal:
we want to use the vMX (M) in Azure in routed mode.
(with firewall function)
There are two networks configured in Azure:
10.10.16.0/28 for the vMX (WAN)
and 10.10.17.0/24 for the VMs
The support told me that I should use on the LAN side
the default Meraki network (192.168.128.0/24) should be used.
Over the site-to-site VPN I would then need to use vpn subnet translation, correct?
Or how did you solve this?
3 REPLIES 3
GreenMan
The VMX in routed mode does not support firewall function at this time.
Did you read this?   :   https://documentation.meraki.com/MX/Other_Topics/vMX_NAT_Mode_Use_Cases_and_FAQ
Thanks for your support.
Merkai Support wrote me the following:
You may use your vMX as gateway/firewall via NAT/Semi-Routed mode but it is limited as there aren't any VLAN interfaces.
Inderdeep
Excellent written here
How to deploy a Cisco Meraki vMX100 into Microsoft Azure • AboutNetworks.net
Regards/Inder
www.thenetworkdna.com
