Search instead for
vMX 100 multiple subnets
Hello Community!
I was wondering if you could help me determine if it is possible to use the vMX 100 in multiple zones/subnets
As far I've seen in the setup guide it only mentions when installing to select a VPC and then a subnet from that VPC.
But is it possible to use it for more subnet or does it will only work within the subnet of the VPC where it was installed?
Kind regards,
EM.
Tags (3)
Accepted Solutions
Re: vMX 100 multiple subnets
I remember how I did this now!
Go:
Security Appliance/Site to Site VPN
Under "VPN settings/Local networks" you can put in all the subnets you use in AWS from all the availability zones in the region.
2 REPLIES 2
I setup one for a client that could access two subnets in Amazon.  I'm pretty sure I did this by adding a static route on the vMX to the second subnet and saying to include that in AutoVPN.
However when I go to look at it now I can't get to the section where you can add static routes.  The route table does show both of the subnets used by the client in Amazon AWS.
So now I'm not sure.  Either it used to allow static routes and doesn't now, or - well I really can't think of any other option.
Go:
