- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
too many connections
We have two MX 105's in building A setup in passive failover mode. Along with this, we have dual ISP's to minimize any single point of failure. Everything works the way its supposed to.
We have building B that is connected to A with a privately owned fiber however, that fiber connection has been identified as a single point of failure.
We are purchasing a new internet connection for building B, and we are looking at purchasing new meraki hardware but we aren't sure of the best way to set this up such that building B uses our privately owned fiber as a primary connection between buildings, but if that connection fails, it automatically switches over to using a site-to-site VPN to building A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Make a transit vlan/ subnet between the two devices.
Then create all static routes with tracking with next hop the other mx ip
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Routing_Behavior#Static_Route_Tracking
This describes it better but instead of mpls you use the fiber
https://documentation.meraki.com/MX/Deployment_Guides/MPLS_Failover_to_Meraki_Auto_VPN
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You could also buy a second private fibre, and LACP can channel them together (assuming it is a point-to-point fibre). This would also double the bandwidth.
