Hi @BrentB,
Is my understanding correct that your topology is the following: Z3 <-AutoVPN-> MX_A <-Non-Meraki VPN-> MX_B in other org; and you are trying to route traffic between Z3 and MX_B through MX_A?
If so, unfortunately, this won't be possible.
The KB says (in a blue note): "An MX that builds tunnels to both Auto VPN and Non-Meraki VPN peers will not route traffic between other Auto VPN peers and the non-Meraki VPN peers unless BGP routing over IPsec VPN is enabled for the latter."
With this said, you can try to configure this new route-based tunnel with BGP over IPsec, and then in theory routes within the same org should be advertised via iBGP, and from the outside - via eBGP, but honestly, I never worked with this feature so not 100% sure it'll work, but if it does, it fur sure will be a good solution.
If that doesn't work though, I'm afraid the only way to communicate from Z3 to MX_B is a direct non-Meraki VPN tunnel between them.
