non-meraki VPN peers
Yasuomi
Set up three site-to-site VPNs in Organization-wide settings. (non-meraki VPN peers)
The two sites are pure VPN communications, but the one site communicates all Internet traffic.
Question 1, Does the configured “Non-Meraki VPN peers” work in order from the top?
Question 2, If a guest network is created and provided, is it possible to have the traffic communicate directly from the WAN of MX without communicating with Site1?
Question 3, If source IP and destination IP are specified in "SD-WAN & traffic shaping" Flow preferences> Internet traffic, will it take precedence over non-meraki VPN peers settings?
Thank you very much.
I am Understand.
ありがとうございました。
DensyoV
Please find my answers below:
- No, it is based on the destination subnet whichever is more specific. You may verify it from the routing table of the MX.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Routing_Behavior
- If the guest network is not advertised to the VPN on the site-to-site VPN configuration then it won't be able to communicate across the tunnel
- No, the Meraki will only form a VPN to a non-Meraki VPN peer on the chosen primary uplink
Hope this helps.
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
Thank you for your reply.
-- This question is a non-meraki VPN peer, not Meraki auto VPN.
-- When the default route is directed to Site1 (non-meraki VPN peer)
Can guest network clients communicate directly from the MX WAN?
Thank you in advance.
ans: advertising local LAN to VPN applies to both auto-VPN and non-Meraki VPN peer
ans: there is no option to configure source-based from the Dashboard but please call the Meraki support if they can exclude the guest network from full-tunnel or using the default route via the VPN
I am Understand.
ありがとうございました。
