MX65 Client VPN with UPN
Stach53
Community Members
I have been unable to use UPN (User Principal Name) when entering credentials for Win10 client VPN. The AD connected PCs accept UPN without issue but client VPN requires sAMAccountName.
Basically, client VPN requires this format
Domain\Username
But any other connection to the DC can use the Username@DomainName format.
Has anyone else experienced this and if so were you able to fix it?
Best Regards,
Stach53
jdsilva
When you're doing a direct AD connection from the MX it looks like the domain/username format is the only supported format.
The client config guide indicates that it must be domain/username:
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_Overview#Active_Directory
I don't see anything in the main KB doc that indicates otherwise either.
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
Maybe a good question for support if no one here has an answer. I only have one customer using this and they're doing domain/username.
7 Replies 7
Nash
How are you authenticating users to your client VPN? When I use RADIUS, folks just enter their user name to login. No domain name required.
Stach53
It is using Active Directory authentication.
jdsilva
Stach53
UPN will not work with older clients like W98 and prior. Maybe it's for backward compatibility but W98?? Thanks for the input JD.
Nash
May I humbly suggest that you really should replace anything older than Win8? Changing the W98 machines to Win7 would be better, even though Win7 is going end of support shortly.
Edit: Unless I misread and this is MSFT retaining backwards compatibility to Win98. In which case, uh, I absolutely have clients with e.g. domain-joined HVAC controllers that run on Win98 that won't be going away any time soon. What horrors lie in network shadows.
Stach53
We're all Win10 but being x-manufacturing, I understand the need to retain old OSs. Still wish they would allow both user name types. It doesn't take much to confuse the end users when you have different naming conventions at password time.
I have a manufcaturing client still using MS-DOS.  The MS-DOS computers are embedded into large one-off custom built factory machines.  The cost of changing the manufacturing plant is eye watering.  So MS-DOS will be around for a while for them.
