Based on your route table, if the destination IP matches the 192.168.X.0/24 network then the traffic should be routed to ASA. However, if it does not match and falls under the default route 0.0.0.0/0 then it will go to the Palo Alto because it has a higher priority than the default route over the WAN connection.
If you suspect that the traffic is not routing over the IPsec even if it matches the 192.168.X.0/24 destination subnet, then you may need to call Meraki support so they can check whether this is the case or not.
Hope this helps.
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
