meraki MS, MX and MR ordering guide
Lenny
Hello I'm trying create estimates on CCW but for MS120-24P-250W, Cisco Meraki MX67  and Cisco Meraki MR33          need some assistance
Accepted Solutions
merakichamp
Re: meraki MS, MX and MR ordering guide
@Lenny  don't bother the cons information that will pop up below just click add and it will be added with price
7 REPLIES 7
rwiesmann
What is your question on it...licensing?
Lenny
i want to order only hardware
  • Cisco Meraki MS Series MS120-24P-250W
  • Cisco Meraki MX67
  • Cisco Meraki MR33
merakichamp
@Lenny  if you have the ccw account then go ahead and create the estimate key in the skus below
MR33-HW
MX67-HW
MS120-24P-HW
please you will always get the part numbers on the datasheet
merakichamp
Lenny
Thank you very much @merakichamp  and @rwiesmann I have successfully created the estimates on ccw
GreenMan
You know you can't use the devices without licensing though, right...?
IngSuzzy
may be is an spare item, because the equipment also needs power cables.... and if its only the hardware what he needs... i assume that he will use the power cable and license like if it was an RMA.  Hope so
